Hello all! I'm looking at building a Street Touring car for next year's autocross season, and since Porsche just became un-excluded from the STS2 class I thought I'd see if a 914 can get it done. I know a member here built one and did well on a local level, but I'm looking for a championship car.
I was excited to see Porsches become legal because they always do so much better than the numbers would imply. Still, I need to make sure the numbers make sense before diving in. There's another car I think might have a better chance, but it's not a car I want to own for any reason other than being classed well. A 914, on the other hand, would just be a great car to have.
I'm hoping the Porschephiles here can help me out with my research. I want the lightest, most powerful 914 that can fit the biggest tires and take to the STS2 legal mods the best. For those unfamiliar with SCCA Solo STS2 rules, the car must come exactly in factory configuration except for the allowed mods. This means no using '74 engines in a '70 chassis, etc.
Rules allow cars with 1900cc motors or smaller.
Here are the allowances I'd want to exploit:
Dampers are open as long as they mount to stock points.
Anti-roll bars are open.
Wheels are open, tires are limited to 140 treadwear. More about tires later.
Springs must be stock type (torsion all around, right?), and must mount to stock points, but are open in rate.
Non-metallic bushings are allowed.
Camber kits of any type are essentially open.
Lightweight batteries are allowed.
"The air intake system up to, but not including, the engine inlet
may be modified or replaced. The engine inlet is the throttle body,
carburetor, compressor inlet, or intake manifold, whichever
comes first."
Chipping is allowed. On EFI cars a Mega-Squirt system may be installed in the factory housing, using only factory sensors.
Engine pulleys are open.
Seats may be replaced with seats weighing at least 25lb with mounting hardware - probably not an advantage with a 914.
Exhaust is free, but cats must remain in the stock location.
Suspension I can handle. I'll dig around for info on my own.
I really don't see much weight loss coming from that list How light can I get from headers/exhaust, battery (assume 10lb replacement), seats (are stock under 25lb with hardware?), and anything else on that list that can replace a heavy component? Note that I can replace control arms as part of the camber allowance.
Please say well under 2000lb!
Tires and wheels. I am going to assume a 225/45R17 is out of the question. With that out of the way, all my options are about the same size and should fit great: how about a 205/40R16, or 205/50R15? Or, could I squeeze a 215/45R16?
How about power? Is the 1.7L the way to go with those mods? Can I change engine management without adding sensors? I'm still checking out some threads, but so far I haven't had luck finding details. Not many people force themselves to work within these constraints, so it doesn't look like much of it has been done on the engine side of things. What does a decent condition bone-stock 1.7L put down with headers and exhaust? Custom headers are not out of the question.
Any help you can provide is much appreciated. I hear y'all are very good with knowing exactly what models came with what options and how much they weighed, which is a huge help in picking a car to start with.
Thanks,
-Phil
