The previous owner started to relocate the fuel pump to the front of car via an aa relocation kit. It is located under the car in the area of the steering rack. It is bolted to the floor underneath using some rubber mountings. My question is this: how do you hook up the fuel lines to it?
There is one fuel line coming off the tank with a fuel filter connected. This should connect to the pump but which hose connection?
I have another line that splits into a y. One part of the "y" is connected to the pump closest to the power wires. Where does the other two parts of the "y" go?
Finally there is another hose connection to the pump. What should be hooked up there?
So we got two fuel lines running from the front of the car back(which now has tangerine s.s. fuel lines, two hose connectors on the tank, and 3 hose connectors to the pump. What am I missing?
