914nerd
Apr 7 2007, 07:43 PM
What does the stock coil wiring look like for an L-Jet car?
Thanks in advance,
Charles
Cap'n Krusty
Apr 7 2007, 08:12 PM
There's a heavyish black wire on the 15 (+) side of the coil, and 3 wires on the 1 (-) side. Those wires are green (from the points via the condenser, a thinner black with a violet tracer (tachometer), and white (encased in a gray sleeve) which goes to the ECU. DO NOT confuse the 12v + wire with the tach wire! Of course, there's the large "coil wire" coming out of terminal 4, going to the distributor cap. The Cap'n
malaga_red75
Apr 7 2007, 09:20 PM
Hope this helps....i have two toher ones that might work also..but this is off my 1.8 L-jet, i replaced it a few months back and took a picture of the connections so i wouldn't forget them.
-PEter
Brando
Apr 8 2007, 03:42 AM
You're running a compufire or pertronix unit, though.
