echocanyons
Apr 9 2007, 09:02 PM
So after the recent noise with my 3.0l six I tried changing the throwout bearing, and that seemed to work, but the noise returnedf and I couldn't relly pin it down, it didn't really seem like the chains but I figured what the hell I will pull and inspect anyway.
Here is what I found. I thought oh good it's not the tensioners they look good.
Can you spot the problem?
Eric_Shea
Apr 9 2007, 09:05 PM
Ahhhhhh... no.
Martin Baker
Apr 9 2007, 09:07 PM
I see Vic Elford...
hmeeder
Lack of photo attaching skillz?
echocanyons
Apr 9 2007, 09:10 PM
OK it's now attached
Eric_Shea
Apr 9 2007, 09:17 PM
Missing a set screw?
Dave_Darling
Apr 9 2007, 09:19 PM
I know, two too many cylinders, and the cam is out on top of the head instead of inside the case where it belongs!!
OK, I can try to guess on that not-overly-familiar motor: The tensioner looks to be collapsed against the safety collar. That, and the idler sprocket mounting bolt (??) doesn't look like it's very well attached.
--DD
Aaron Cox
Apr 9 2007, 09:20 PM
piston failure safety collar is missing a screw
echocanyons
Apr 9 2007, 09:30 PM
Nope it's only missing half a screw
, well I guess not missing it's prolly tucked away nice and safe in the case somewhere (unfortunately this is a late case with no sump plate).
Are these keepers really expected to hold the tensioner when it fails?
This is a picture of the back of the tensioner "saver" you can see the back of the screw still attached.
Kind of ironic that the tensioner guards failed and the tensioners are still fine huh?
Any easy way to retrieve this or am I looking at splitting the case?
McMark
Apr 9 2007, 10:07 PM
You can try a magnet, but it's a shot in the dark. You might get lucky. Here's an idea of where it went.
Of course, maybe the person who installed them overtightened them and snapped a head off while installing. In that case you wouldn't have anything dangerous in your motor.
echocanyons
Apr 9 2007, 10:15 PM
Thanks for the picture! that looks like a late style case like the one I have (without the sump plate).
Did the oil pumps on the late cases came with screens?
Cap'n Krusty
Apr 9 2007, 10:52 PM
QUOTE(echocanyons @ Apr 9 2007, 09:15 PM)
Yes, they came with a screen. That tensioner looks collapsed. The collar should be 4mm above the tensioner body, and the piston usually sets farther out than that one. The loose collar wouldn't cause the noise, a loose chain would. Chains get loose because the tensioner bleeds down. Kits are available. I rebuild NEW tensioners before installation. The Cap'n
Justinp71
Apr 9 2007, 11:13 PM
Is that the correct nut on the cam sprocket?
Here is my left sprocket on the 2.7.
Mike D.
Apr 9 2007, 11:41 PM
QUOTE(Cap'n Krusty @ Apr 9 2007, 09:52 PM)
with the CAP'T. I had the stops in my 2.0 6 and had one tensioner fail. The stop held but it did make a lot of noise, kind of resonates chain noise. And yes the safety stop is supposed to be in the middle of the piston not resting on the cylinder like the one in your pic.
echocanyons
Apr 9 2007, 11:57 PM
The only reason the safety collar is sitting on the tensioner body is because the collar is not held tight to the tensioner.
Do you think I need new chains, I plan to do the hydro tensioner change while I have it apart(unless you all thin otherwise)?
I am pretty sure they changed the cam/cam nut design in 82, my 80 engine looks like yours, this is an 83.
John
Apr 10 2007, 12:07 AM
QUOTE(Justinp71 @ Apr 9 2007, 09:13 PM)
Yes, that is the correct bolt.
Post 2.7 had different cam sprockets and use different holding wrenches.
Justinp71
Apr 10 2007, 12:27 AM
QUOTE(John @ Apr 9 2007, 11:07 PM)
oh... okay, I need to replace my chains also... (motor currently out).
I am planning on putting the fail safes on to...
echocanyons
Apr 10 2007, 12:34 AM
Justin, I am no expert but it looks like you may have some chain stretch, it looks like the clearance from your tensioner lever to the housing is really narrow, what does the other side look like?. EDIT oops I see you mentioned that in your post...
check this tread out
pelican chain stretch thread
So.Cal.914
Apr 10 2007, 12:47 AM
I think the chain looks Ok but I would take echo's sudjestion and read
the pelican thread and check it while you are there. Thant goodness more damage
was not done.
Cap'n Krusty
Apr 10 2007, 09:55 AM
I certainly wouldn't waste my money, or that of my customer, on the silly tensioner changeover. The last version of the original chain tensioner is fine, and rebuildable. Why spend a bunch of money on something that can have the same failure problem?
This is one of the far too many times when the term "upgrade" is misused on the internet.
The Cap'n
Mike D.
Apr 10 2007, 12:04 PM
QUOTE(Cap'n Krusty @ Apr 10 2007, 08:55 AM)
The Cap'n
So what is your opinion of the Carerra Tensionsers? I was thinking about doing it to my 3.0, but for no other reason than "if everyone else is jumping off the bridge..."
Justinp71
Apr 10 2007, 12:12 PM
QUOTE(Mike D. @ Apr 10 2007, 11:04 AM)
The Cap'n
Cap'n- are you talking about the 930 tensioner? New they're over $200 each and you can get the Carrera kit for around $489 from ebs racing. Why not spend the extra $50?
Also my tensioner appeared to lose some tension after the motor was sitting for about a week, but as soon as I turned the motor over they tensioned right up.
Is that a sign of a failing tensioner?
echocanyons
Apr 11 2007, 07:59 PM
Well the bolt came out through the engine drain plug with a little bit of coaxing.
Fortunately it was in one piece and didn't look banged up.
Now on to replacing the tensioners!
