QUOTE(machina @ Apr 10 2007, 02:09 AM)
QUOTE(r_towle @ Apr 10 2007, 12:45 AM)
with carbs.
you need power to the coil. 12 jumper lead
power to the fuel pump jumper lead
push button from yellow lead on the starter to power on the battery.
the button needs to be rated for 50 amps or it will melt.
Dont crank to long or the wire will melt.
Rich
my ignition and fuel pump are already on there own circuit with breakers. so can i just run the swith leads between the 2 wire on the starter then?
The big fat wire on the starter goes directly to the battery.
For me, I find it very hard to hook up two alligator clips one the starter and sensure that they never ever touch each other...
Its just to close, and when the engine starts, its vibrating so much that they could (and have) touched...which melts all sorts of stuff down there, including the solenoid...
So, I clip one to the little yellow spade terminal, and run the other end directly to the battery...I find it safer and less to worry about while I have my head in the engine bay....
And, if there is a problem, like the switch melts into the on position, and the starter stays engaged (BTDT) I can grab the wire off the battery pretty quick.
I have used this rig for 25 years..lots of used motors from junk yard cars...its the simplest way to test to see if the motor turns, and start..
So, over the years, I have melted a few switches by cranking to long, even 50 amp ones can only take so much...and wires, and welded aligator clips together.
I am just offering my experience...and the mistakes I have learned from..but hook it up any way you like.
I never ever ever start a car with my head underneath the car.
I have started a few american cars with just a screw driver jumping those two terminals...but on these cars, you gotta have your arm up under the car, over the drive axle...not a place I want to get out of in a hurry...
Rich
