I've seen a few guys use impact guns at an autocross and felt as though I should give my hands a break. Changing tires manually spinning a socket takes a hell of a long time. I could use a + lug wrench but would rather go the electric route.
Any suggestions? Brands/models to avoid?
I'd like to keep the price under $150 if possible. I don't mind cracking the lugs manually, but regardless the lugs will torqued with a torque wrench.
I don't see that many +12VDC guns, not enough juice?
The idea of a drill with a 3/8" adapter would work fine running off an AC inverter. Anyone go this route? Certainly the budget way of doing things.
Here are a few links: http://www.etoolcart.com/index.asp?PageAct...mp;Category=357
Thanks
