I just had an engine rebuild, and after 25 years of ownership, I now have a motor that doesn't leak oil. But, all that means is that now my leaks are only from the tranny. While I had the shaft seals replaced when the engine was out, it look like the drive angle is leaking. I stole the pics below, the top one shows the leak location (this one looks worse than mine). Bottom photo is the drive angle replacement part from Pelican.
What do I need to replace to stop this leak? My drive angle seems wiggly/loose at the interface where it's leaking - I assume it's supposed to rotate?
