QUOTE(jagalyn @ Apr 10 2007, 03:23 PM)
I am restoring a 914 2.0 and am going to relocate the fuel pump back to the original location. I need to see how the fuel hoses and return lines are plumbed and where the filter is located.
I also need to see where the wiring goes through the engine sheet metal.
Any pictures that would show this would be invaluable to me and would be greatly appreciated.
there was a thread here just the other day ...
first, grab your haynes manual, page 41 shows how the fuel pump is connected.
- one line from the tank, with filter inbetween. "S"
- one line to engine. "D"
- one line (using the "Y") hooked into the return line. "R"
page 46 shows the letters for each port ...
- "S" sucks fuel from the tank through the big diameter fuel line thru the tunnel.
- "D" pushes to the fuel injection system.
- Then from the pressure regulator the fuels runs back to the fuel pump,
the plastic "Y" hooks up to "R" on the pump, the other part of the "Y" hooks up to the smaller diameter return fuel line which routes the fuel to the tank.
the wires for the fuel pump (two going to a round plastic connector) come out of the main harness on the pass. side in the engine compartment, at the firewall, under the battery tray/FI brain location.
there's a round opening in the engine shelf on that side with a grommet.
the lines and connector go through there to the pump.
there's two different locations for the fuel filter, depending on the year of your car.
early cars had it on the rear firewall, under the engine shelf, on the pass. side.
later cars had it on the pass. side engine mount bracket.
Andy
