Brew
Apr 11 2007, 07:18 AM
Any idea why my car could be running rich all of the sudden? I even haven't been messing around with it under the hood.
bd1308
Apr 11 2007, 09:16 AM
oil cap not on tight?
alignment of the planets?
Bleyseng
Apr 11 2007, 09:17 AM
CHT is going bad
FPR vacuum hose is off
dr914@autoatlanta.com
Apr 11 2007, 09:44 AM
lean backfire when cold and now a sticking air flow meter flap!
alpha434
Apr 11 2007, 11:19 AM
It's the hose that hooks into the air tube just behind the flapper box. It's come a little lose, and you're losing vacuum. I seal mine with teflon and a hose clamp. If you pull the hose out, your car will die immediately. I don't know how well getting rid of the hose and plugging the hole would work. It's only function is for the cold idle enrich valve.
Brew
Apr 11 2007, 11:52 AM
A loose oil filler cap will cause this? I bet that's it then, my o-ring disintegrated not too long ago.....
Anybody know off the top of their head what size the o-ring is?
Thanks all!!
ClayPerrine
Apr 11 2007, 03:16 PM
You have it backwards. If the hose comes off or the oil filler cap seals are bad, the car will run LEAN, not rich. You may have what the good Dr. says, or it could be the CHT wire on the RH cylinder head. If it is broken or disconnected, the system goes full rich thinking it is -50 degrees.
Check the AFM first. It is the most likely culprit.
MartyYeoman
Apr 11 2007, 03:29 PM
If the CHT is disconected or "open" the car won't run.
ClayPerrine
Apr 11 2007, 03:57 PM
QUOTE(Marty Yeoman @ Apr 11 2007, 04:29 PM)
Not totally true. If it is disconnected or open, it will be so rich that it probably won't run, unless it is really cold outside. If you remove the oil filler cap, you create enough false air to get it to run, but badly.
