jim_hoyland
Apr 14 2007, 07:32 PM
Getting ready to install the intermittant wiper relay and harness; the stalk on the sterring column was upgraded and the internal tab was removed.
How can I test the intermittant wire thats currently folded back on the harness ?
Can the install be done without removing the fresh air blower?
I did read the thread in the classics and didn't see these answered. Any help/suggestions will be appreciated
Jim
914Sixer
Apr 14 2007, 07:38 PM
Fresh air should come down. Take the two bolts off on each side. This will give you some working room to get to wiper plugs.
jim_hoyland
Apr 14 2007, 07:39 PM
Do I need to remove the gas tank to make room ?
anderssj
Apr 14 2007, 08:07 PM
QUOTE(jim_hoyland @ Apr 14 2007, 05:39 PM)
IIRC, I installed mine without removing the tank . . . but that was back when my elbow was still pretty good.
markb
Apr 14 2007, 08:24 PM
I was able to get to the plugs with some long needlenose pliers. I couldn't get the intermittent to work with the electric pump tho.
Tobra
Apr 15 2007, 10:41 AM
There was a Superbeetle guy who put intermittent wipers on his car by taking switch off late 70's rabbit. My SB came with intermittent and I believe same switch will work in 914 application
jim_hoyland
Jul 7 2007, 09:05 PM
Update; Followed the directions that Sir Andy posted. ( now in the classics ) It worked the first time !
markb
Jul 7 2007, 10:41 PM
Do you have intermittent AND washers?
jim_hoyland
Jul 7 2007, 10:45 PM
QUOTE(markb @ Jul 7 2007, 09:41 PM)
Yes. I didn't expect it to work with the washer either...I guess the washer position also triggers the relay. How's it do that ?
markb
Jul 7 2007, 10:49 PM
Very cool! Maybe I'll have another go at mine.
