QUOTE(Twystd1 @ Apr 15 2007, 10:48 PM)
From Clayton:
DynaMat works pretty well.
But I have a different idea for you. Neoprene...!!!!
The closed cell structure of neoprene is extremely good at damping sound.
For whatever reason... Neoprene has this interesting quality of damping sound from about 240 HZ to 20K Hz+.
I have used it many times to dampen automotive interiors back in the IASCA days of car stereo competition. You can buy 2X3 foot sheets at AAA yardage in Santa Ana on main street. (if they have it in stock) Call first.
You apply it with 3M Super 77 spray glue. I think it would work really well behind the back pad, headliner, foot wells and floor boards.
When used in conjunction with DynaMat or one of it's derivatives. It works extremely well.
AS far as making a steel top for your teener. My only fear would be snapping your windshield from body flex. The windshield pillars aren't fastened very well to the body either IMHO.
If I were to do this. I would fill the pillars with sprayed in structural foam in an attempt to keep the pillars stiff. That goes for the sail panel pillars too. As a byproduct of this stiffening, You will also incrementally help keep the sound down.
My thinking is to transfer the pillar flexing to the attaching point of the pillar and the body body and your proposed steel top.
In hopes of keeping the flex away from the windshield support surface. Hence keeping the windshield from twisting. This would only be an incremental fix. Yet I think it will help. I forgot something... Is your windshield fastened with Mastic or do you have the vinyl strip holding it in?????
NEXT:
Here is bit of what I know about sound deadening for automotive use.
There is no one single solution. It takes several different materials to get a car's interior quiet. It takes time and knowledge. And it is a lot of work if you want to do it right. It takes lots of little things to make it work.
One of the first places to address in a car interior is any HOLLOW spaces. As they act like a speaker cone. Hollow areas not only pass sound. They also create/transfer audible sounds on their own. It's called sympathetic transfer.
These spaces will pick up all kinds of harmonics. Even some you can't actually hear. Then transfer these harmonics up or down to an audible level. Thus creating even more spurious sound waves in the interior of the car. Fun stuff. isn't it......
MORE:
The basic trick of light weight sound dampening..... Is to put as many air bubbles that aren't touching each other. Between the sound emitter. And you ears.
The bubbles then transfer the sound energy into the binding material and bounce the sound around within each bubble... This creates sound canceling as each harmonic of the sound wave hits it's own sound wave within the bubble. Instant canceling of sound...
Where does all this sound energy then go..???
It turns into heat. The heat is radiated away by the binding material into atmosphere.
Mastic style sound dampening like Dynamat works differently. It simply slows down the harmonics and absorbs the sound. Then returns the sound as heat. It works well at higher freqs. I don't like DynaMat alone for sound below 200H z. Closed cell deadening material + DynaMat works better for that for in MOST applications.
I would love to take your car to high end sound shop and throw it on a Stereo Real Time Analyzer (SRTA) and look at the waterfall plots. That would tell us EXACTLY what to do. Problem is... DUH... We would have to have your car on a rolling road Dyno to accurately do this.....
That would be very interesting from a scientific perspective.....
(that was dream sequence #592)
Sound canceling and heavy weight sound dampening is a subject unto itself. Thats for another day...
SO:
Since you have SO MUCH horse power. I am guessing that you don't mind adding another 20-50 pounds to your car for optimal sound quality.
I have been quieting cars interiors for years. I'm pretty good at it.
NOTE: All of this will cost you weight if you want it as perfect as possible.
Swing on by the coffee house and lets chat about it. I want a ride in your teener anyway... I also want to check your ride quality as per our last conversation.
I also have a notion for using FOX dampers which may well help your ride quality. I am not the first guy to think of this or do it for that matter.
At least you would have optimal adjusting to make your shocks dampen any way you choose on both rebound and compression.
And I have a FOX SHOCKS WD that wants to work with me.
If ya want to chat further with this knucklhead.....
PM me for a phone number.
Regards,
Clayton
Clayton,
Sounds (no pun intended) you know something about the subject. Why hasn't anyone filled the longs with structural foam and seal it up ? I thought why not polyurethane, something with some give not a solid, that would surely suck up a lot of vibration. When I had my TT Rx7 I made a lot of my own bushings using that material, but it was a 90 grade a bit too hard. I don't care a bit about weight.
and another thing I saw a Nissan Maxama in a junk yard a few weeks back which had a, if I am remembering correctly, steel rod coated with rubber real thick which was in the trunk area over the rear wheels, I am sure its for vibration control, anyway surely was pointed out via an expensive vibration device Nissan has... Ill PM ya in the AM
John
