QUOTE(Pat Garvey @ Apr 15 2007, 09:13 PM)
Yeah, I know this has been done before. But I have a newfound board from "the basement" that really needs help (see pic).
I've seen about the LET & Body Shutz approach, which isn't bad. But I'm curious about 2 things:
1. Whatever that tar/pitch/bakelite crap is on the backside - how do you soak it off without damaging the body of the panel or the topside electronics?
2. Those who've done the LET & Shutz thing - how's it lasted after time?
This one is dry & cracked on the underside - gooey & tacky up top (though it WAS stored upside down for 15 years).
Pat
After experimenting with all kinds of solvents (none of which seem to do anything),
I found (totally by accident) that the tar stuff chips up and scrapes off
fairly easily when its cold. (I was trying this during the winter in the garage).
The cold temperature hardens the tar and makes it very easy to scrape off.
So I would recommend putting it in either the refrigerator or freezer
a while prior to scraping it off.
I bought a few dental picks but it turned out that the best tool is a flat blade
screwdriver that is the width of the traces. Just push it into the groove
of the trace and slide it along as it chips off the tar.
Hope that helps.
--- bill
