Hi,
Thought I's start a thread so I can talk about my engine conversion.
I have many questions, so I hope I can get answers here! Others also may be
interested as well.
I am swapping out a 1.8l L-Jet engine for a 1.7l carbed engine, I hope! I also
have an almost complete D-Jet FI system for this engine, but I have been assured
that the engine will run correctly with the carb. I hope eventually to build up a
2056 or equivalent from the carcass of the 1.8.
The carb is a Weber 32/36 DFAV 2 barrel progressive carburetor.
Questions
1. Is this carb a reasonable choice for a 1.7l engine? I do not know yet if the cam
has been changed. I sort of doubt it.
2. There are no gaskets for the head ends of the intake runners. Can I just
make them from paper gasket material?
3. Does the carburetor just sit hanging off of the intake runners? There do not
seem to be any brackets to hold the carb down. It LOOKS like it should be ok.
The metal runners slide inside the intake manifold.
4. Where do all the vacuum lines go? There seem to be a lot of disconnected lines
floating around! I am refering to the larger lines that normally connect to the
intake plenum. Small lines from the carb to the distributor are no problem.
5. I did not get a distributor with this engine. Is it okay to use my distributor from
the 1.8? The carb has vacuum advance and retard connections, and so does the
distributor. I'm not talking pefect here, just okay for now. This is a temporary
engine swap (yeah, right! )
6. Any specific recommendations for a fuel pump for this carb? How much will it
cost? How do I mount it? My pump is forward under an inspection plate.
Well, that is enough for now. I will have lots more, and pictures too! I need to pull
my old engine tomorrow.
Thanks for any help!
Jeff
