Which calipers are you trying to mount? on Pelican you mention.....
Boxster,964,993 etc.
I don't think nobody makes them for 3" srtuts
again, not true
Like I mentioned in my reply on Pelican VCI can do this. I called Doug Arnao at VCI and explained..that I needed 993 calipers modified to mount to 3 in struts. He machined both the calipers,and made the proper radial mount adapter for 3" mounting.. No machining of the strut is necessary.
VCI isnt cheap, but instead of reinventing the wheel sometimes its more cost effective to pay up for a solution that works..
http://www.vehiclecraft.com/Brakes/VCI911_2_964.htmQUOTE
I have a set of 951 f & R calipers...will they fit anything?
I think the only real difference between the 951/964/993 calipers is in the piston sizes for the rears.... and the throat on the rears..
Yes you can make them fit a 914, or 911... to do it properly have them machined and made to radial mount. one advantage of this is you can locate the caliper perfectly over th rotor, rather than have pad overhang, or the rotor not centered.
