QUOTE(lotus_65 @ Apr 18 2007, 02:27 PM)
thanks, i'll keep after it. for clarification, it's this:
Click to view attachmentbig bird article and especially, thanks, brer... i only wish i knew what it means!
QUOTE(brer @ Apr 18 2007, 02:00 PM)
bo selecta!
GOOD!!! You tool the roll pin out of the correct end of that shaft. For some reason, when the roll pin is removed from the shaft inside the transmission, it will eventually shear after reassembly. This leaves you stranded in 3rd gear in the hills around Austin, and makes you beg garage space from one of the locals on the tour so you can install a borrowed shift console..........
If you have someone who is really good, have them TIG the selector fork onto the shaft so it won't happen to you.
