QUOTE(914nerd @ Apr 18 2007, 10:33 PM)
I have sufficient fuel pressure, and I have spark
But the car doesn't start, except for occasionally
What is a likely culprit?
Cold Start Valve? Thermotime switch? hat are the specs on these so that I can test them.
Has anyone else had this problem or know of some reasonable solution to it?
Thanks,
Charles
How have you verified you have fuel pressure? Does the fuel pump run when it is cranking? How do you know this?
I would start by making sure that it will actually run if it has fuel. Spray some carb spray in the plenum, then try to start it. If it starts and dies, you can rule out any ignition problems.
Next, see if the fuel pump actually runs. Disconnect the yellow wire from the starter, and turn the key to the start position. You should hear the fuel pump run. Then open the Air flow meter with the key on, and make sure the pump runs like that too. IF the pump won't run when you crank the motor, it will never start.
Then I would verify you have injector pulses. Get a noid light for bosch injection from your FLAPS and plug it in in place of one of the injectors. If it flashes, then you have injector pulse. Check all 4, because the L-Jet can break wires in the dropping resistor pack and leave you with dead cylinders.
Then I would make sure that there are absolutely no vacuum leaks. I would replace the oil cap seals, and check the tube between the throttle body and the Air flow meter for tears.
Try all that and let me know the results.
