1. Drop engine/trans and pull flywheel. Ship flywheel to So Cal for ring gear "adjustment"
2. Get new fuel pump and install.
3. Sort last small issues with wiring. (right blinker grounds and blows fuse...) ????
4. Re-mount remote water pump to eliminate air pockets.
5. Re-curve distributor advance w/new springs and weights. (not enough advance at higher RPM's)
6. Touch up a weld on modified shift rod.
I think that's it.
What have you got left to do?
Gotta' go and git 'er done!
