QUOTE(obscurity @ Apr 21 2007, 10:35 AM)
QUOTE(MecGen @ Apr 21 2007, 08:48 AM)
A quick side point...GV sheet metal is not only a real bitch to weld, its even worse to paint. The fact that it is resistant to rust also makes it horrable to get the paint/primer to stick. Every Tradesman I have spoken to has told me to stay away from it.
Is there an alternative for replacment metal? I am doing the Hell hole and surrounding area. The various kits are not extensive enough. Aside from cutting up another car, which more than likely won't work since any car that has these parts in good shap is probably not one you'd cut up, whats a boy to do?
Seriously I would love to find an alternative to using galvanized metal but there are very few alternatives and galvanized reduces the possibility that I will ever have to do it again (to this car).
John
I don't believe that using galvanized will reduce the possibility of rust issues
over properly treated and sealed/painted steel.
It could make it worse as many primers and paints don't stick to zinc very
well so while you may pick up some protection from the zinc, you very
well may lose protection if you can't get a good paint layer to stick to the metal
especially along the boundary edge where the zinc has been removed.
i.e the paint may come up at the point where the welded steel transitions
back to the galvanized metal and you lose the protection for the ungalvanized
areas.
I would completely avoid any galvanized metal.
The reason is the Zinc vaporizes at a lower temperature than the steel will
be heated to during the welding. This is why using galvanized metal is so toxic.
The zinc is vaporizing and can/will be inhaled as you are welding.
Living in Atlanta you should easily be able to find a scrap yard that can
can get you all kinds of sheet steel at very reasonable prices. I found
a place here in Dallas that will sell me whatever I need at 70 cents/pound.
WAY cheaper than any big box hardware store, and I can get any thickness
and size I need.
Here is a link that helped me find a place I used here in Dallas.
They list some stores in Atlanta
Metal SupermarketAnd for those factory style pieces like battery tray, battery shelf, wheel wells,
firewall pieces, or engine shelf you can even drop by Automobile Atlanta.
Auto AtlantaThey have any thing you might need.
Hear a few more of the several places that sell these sheet metal parts as well:
Restoration DesignPelican PartsTweeksTweeks has some great prices including a factory battery tray replacement
for $3.99 - Yes this is not a misprint!
Hope that helps.
--- bill
