QUOTE(Gint @ Apr 21 2007, 11:05 PM)
QUOTE(Aaron Cox @ Apr 21 2007, 04:10 PM)
QUOTE(Gint @ Apr 21 2007, 09:36 AM)
QUOTE(Cap'n Krusty @ Apr 21 2007, 09:07 AM)
QUOTE(Gint @ Apr 20 2007, 07:10 PM)
Other than 2 ropes tied to your foot, that's the LEAST desirable style of linkage. The crossbar/lever linkage is far better. Porsche used it from the earliest 356s through MFI 911s (nearly 25 years). The Cap'n
Thanks John, but I'm going to try it and draw my own conclusions based on my own experience. Of the few people I know using this linkage though, none of them have anything bad to say about it. And we all know you're bias towards factory stuff. Having to unscrew the drop links on the CB crosbar linkage to remove them just blows IMHO. I'm sick of it. The Triad setup is probably the best out there, and I'm not that cheap, but the price is just too much. I have a 2.0 DJet FI motor that I will put in this car before I spend $200+ on carb linkage.
yeah gint, because that style really encompasses thermal expansion
my favorite joe sharp quote "you have to understand it, before you can use it"
pretty simple, and i agree with john
and the triad is probably a bit better thanthe CB... justs costs too much LOL
Llike I said, I'm going to try it and draw my own conclusion based on my own experience. There is just too much debate and differing opinions regarding dual carb linkage. If it doesn't work worth a damn I'll be sure and let you know. To tell you truth, the CB linkage would be a much better if the drop links were the 914/6 style that pop off instead of the heim style that have to be unscrewed.
the ball and cup joint can be had at Mcmaster Carr, or grainger etc...
I agree about the heim joints..they were gone fast on mine.
Personally I dont like any of the cross bar linkage...its just not right, and cant ever be right, and this includes the 356...
The 356 is probably the worst total accel linkage setup I have seen...
It works, sure...but lots of things work...just how much compromise do you need to have...
BTW the 356 has two bell cranks, a cable, and a slider rod all before you get to the cross bar...a good 1/2 inch of slop is normal...
Any of these cross bar linkages just cant work correctly with cast iron cylinder, cast heads and a cast case...dont forget the manifold and carbs...
These parts are all made from different alloys that expand and contract differently.
So the left side of the motor could, and I bet does, expand and contract differently from the right side.
I have tried every cross bar linkage setup so far...they all have the same issue
When the motor changes size, the angle of the drop linkage changes (from one side to the other) and then the carbs are not being activated the same..
I wont bother anymore...and I went down a much more flexible road..
I built myself a really robust cable system that has loads of benefits...
I wont post pics just yet...but within a few months I will show a decent looking prototype (a nice machine shop one, versus my homemade one) and I will show the three things that it solves..
Hopefully it will actually works better then that cross bar linkage..but only time will tell.
Rich
