well..my 1972 914 V8 will be here Sunday. I am excited......
BODY
-Rayco FRP front fenders
-Mitcom 916 rear quarter panels
-P.B. Tweeks FRP flared rocker panels
ENGINE/DRIVETRAIN
-1970 Rover/Buick all aluminum 215-V8
-STD bore, 10.5-1 (stock) comp ratio
-Cyl heads-ported exaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction.
-Camshaft-M-488 custom ground by Shadblot engineering(Vancouver B.C.) C/W hydraulic lifters
-Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under - rods ground .001"
-Hi volume oil pump, Buick v8 filter housing
-Facet electric fuel pump-GM canister filter
-Offenhauser alum intake
-500cfm Carter carb C/W electric choke
-Buick distributer with Unilite conversion
-Kennedy engineered product #1000 Rover to Porsche adapter
-KEP 2400# max pressure plate
-KEP throwout bearing
-V.W. 200mm clutch disc
-Custon h.d. radiator w/ twin Spals
-Toyota Corolla heater
ELECTRICAL
-Hella H-4 Q.I. headlites
-Eurolens rear tail lites
-Tach converted to 8cyl
-Mechanical oil pressure and water temp
-Electrical oil temp and cyl head temp
-Alpine CD with JBL audio speakers
-Electric windows
-Keyless entry
SUSPENSION
-H AT H Carrera 19mm adj front sway bar
-Addco 16mm rear sway bar
-140# rear springs (100 stock)
-Stock front torsion bar
-Koni adj front and Koni H.D. rear shock absorbers
-BMW 320i front brake conversion
-Stock Porsche rear calipers
-All four calipers have stainless steel liners and completely rebuilt.
-Adj proporsioning valve
-19mm 911 master cylinder
-All rotors have been crossdrilled
-All flex lines are braided stainless steel
-Pagio performance brake pads, all four wheels
-Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear
-Custom roll bar with rear chassis supports
all that...
Now if I can just clear a spot out of the garage for the new arrival!! Come on guys... buy my 73!!!
Michael
