QUOTE(jasons @ Apr 21 2007, 08:03 AM)
QUOTE(geniusanthony @ Apr 21 2007, 04:26 AM)
ok with a bosch blue, where do i connect the purple black, red black , and geen from the distributor, haynes is less than helpful here...
purple/black = Tach, goes to negative
green = Points goes to negative
red/black = Switched Power goes to positive
And positive is marked "15" (+), negative is marked "1" (-). In wiring diagrams the center terminal is identified as "1". The positive wire, stock, is substantially thicker than the tach wire. Didn't we do this one a couple of weeks ago? Doesn't the archive search function work?
The Cap'n
