http://www.914world.com/bbs2/index.php?sho...c=390&st=20
This answers a lot of questions, but that thread mostly talks about Boge struts, spindle mods, etc. and doesn’t 100% clear up a question I have about KONI insert compatibility.
My confusion comes from the KONI application guide http://www.koni-na.com/pdfcatalogs/2007applguide.pdf (approx 1 MB PDF). If you don’t want to look at the PDF here is a summary of the KONI document …
65-68 911
Boge strut 86-1394 Classic
KONI strut 86-1308 Classic
69-74 911
Boge strut 8641-1039 Classic
KONI strut 86-1638 Classic
75-89 911
Boge strut 8641-1039 Special
KONI strut 86-1942 Special
(footnote) 8641-1039 Sport
914 and 914/6
All (Boge?) 8641-1077 Sport
To translate KONI types, Classic = “Black”, Special = “Red” and Sport = “Yellow”.
The implication is that "it appears" that you are really limited if you want to use the “Sport” insert as they only list the “Sport” strut for the 914 and 914/6 as well as for the 75-89 911 (but with a cryptic footnote). The 911 footnote says…
“Ext. adjust Sport alternative (both Boge and KONI) for OE KONI struts, gland nut 73.25.01.011.1 must be ordered separately”
My confusion/questions…
- Is the dimensions/structure of all Boge struts the same and all KONI struts the same (I understand that Boge and KONI struts are not the same)? If so, using Boge struts as the example, ANY Boge “compatible” insert will “fit” ANY Boge strut regardless of the year of strut and model of insert?
- That the KONI strut has a larger internal diameter and that the Boge is smaller? That the special gland nut they mention is first threaded into the KONI strut (Its external thread match the KONI struts threads) and then the Boge compatible KONI insert screws into the gland nut?
- I am making a lot of assumptions here, but if the above is true about the gland nut, does that mean that you can take ANY of those KONI inserts and using the special gland nut use it in ANY of the Boge struts?
- That the KONI application guide actually lists recommendations based upon OEM replacement and insert valving. For example if all of my above leaps of faith are correct (in that you can really mix and match) that if you do, you may just have incompatible insert valving that will affect handling dynamics. BUT it also means that you can use the proper 914 KONI "Sport" insert (that is properly valved for the 914) in any of the Boge or KONI 911 struts!?!?
- This is more of a question for someone at KONI, but they list the 8641 “series” as being externally adjustable. Basically it looks like all of 8641 inserts are “sport” types. But the above into lists the KONI insert for the 75-89 Boge strut as “Special”, but not “Sport” even though it is an 8641 series insert. Maybe this is a misprint and it really is a Sport insert?
One last thing…
I have tried to document everything that I have learned on the 914 Wiki. Please feel free to look at that article and if you think you know what you are talking about, correct any mistakes.
http://www.roadglue.com/wiki/index.php/911_front_suspension
