The ignition switch on my /6 has been balking lately. I'm looking for some advice. Inserting the key can be a tricky job. Seems like lots of metal-to-metal bumping when inserting the key. Once inserted it will turn from "off" to "on" okay but frequently won't turn to the "start" position. More aggravating, it will go into the "start" position while I'm working to get it started cold. Just about the time it seems the car is thinking about starting I'll turn it back to "off". *Then* it refuses to go to the "start" position! The steering wheel lock works just fine.
Does this sound like worn tumblers or missing lube? Something else? Is this beast repairable? If not, are /6 ignition switches available (I seem to recall they basically are not).
Thx,
Skip
