Rusty
Apr 22 2007, 12:07 PM
Here are a few tips I learned the hard way.
1. Wear safety glasses when grinding. You only get one set of eyes.
2. Keep a fire extinguisher nearby when working on fuel lines.
3. Disconnect your battery and your FI control box before welding on your car.
What are your best safety tips?
So.Cal.914
Apr 22 2007, 12:11 PM
1)Don't get your hair caught in the armature of a power tool...it will real you in
2) Wear hearing protection
3)When ever possable don't ground yourself and then touch the business end of a welder.
r_towle
Apr 22 2007, 12:30 PM
1) Lock the door so your wife cant get in.
2) turn up the radio so you cant hear if anyone is yelling for you.
On a serious note.
the top two injuries in the auto shop accoriding to a national study by NADA are eyes, and hands.
So, wear eye glasses....38% of the accidents are eye related in a shop.
Wear gloves, lots of hand injuries.
Rich
LvSteveH
Apr 22 2007, 12:31 PM
If a little voice tells you that something isn't right...... LISTEN
toon1
Apr 22 2007, 12:37 PM
don't trip over the tonuge of the boat trailer and fall into your work bench. did that last night, hurt like an SOB, LOL
KaptKaos
Apr 22 2007, 12:41 PM
Put a rim under the car when working with jackstands.
/Gint's Axiom?
Aaron Cox
Apr 22 2007, 02:26 PM
make sure your jack isnt leaking....
davep
Whenever possible, don't work alone.
TROJANMAN
Apr 22 2007, 02:28 PM
Have Brant do all of the hard stuff
JPB
Apr 22 2007, 02:32 PM
When working with solvents, for God sakes, remember not to make manual contact with your privates unless you plan on entertaining near by on lookers as you show them your Galic like fancy footwork while using profane language which makes them focus on your genitalia in outburtsts of laughter.
Talking form experience here.
Apr 22 2007, 03:31 PM
QUOTE(Lawrence @ Apr 22 2007, 10:07 AM)
wait with the beer until the majority of your work is done ...
don't drink and wrench!
Andy
northern chris
Apr 22 2007, 03:58 PM
When welding always make sure all skin exposed to the arc flash is covered, its a great way to get a bad sunburn.
When drilling holes in small pieces of sheet metal always make sure the piece is well secured will something other than your gloved hand. Spinning sheet metal is a great way to get a good cut.
Crazyhippy
Apr 22 2007, 04:01 PM
QUOTE(northern chris @ Apr 22 2007, 02:58 PM)
Now how am i gonna get tan?
NO sandals in the shop...
Brando
Apr 22 2007, 04:02 PM
1) Two pairs of jack stands are better than one.
1a) Keep that jack up under the car 'just in case'.
2) When working with items that need to be heated to install (gears, bearings, etc), don't use the oven in the kitchen!
3) Keep your cell phone on you and easily reachable in case you need to make a 911 call.
4) No more than 1 litre of beer on your lunch break.
5) When using power tools such as grinders, sanders, welders, etc; take a break every hour or two to let your hands stop swelling.
6) Common Sense Isn't.
Dave_Darling
Apr 22 2007, 04:07 PM
Jack stands are your friends. Jacks sag, jack stands don't.
Don't trust the jack stands implicitly, either--have a back-up method of supporting the car, just in case!!
Wear safety glasses, or a full face shield!
Gloves are good--latex or nitrile for fine work, leather and/or cotton for heavy work. They'll keep you from leaving too many bits of knuckle in the car.
Always have a fire extinguisher handy.
--DD
Betty
Apr 22 2007, 04:12 PM
If you're doing something that requires the presence of a fire extinguisher and the car will roll..... move the car outside before you commence. The garage/house you save from burning down might be your own!
watsonrx13
Apr 22 2007, 04:27 PM
Keep a bucket of water close by when using Aircraft stripper...
Always remember to take frequent water breaks when working in a hot enviroment...
-- Rob
ClayPerrine
Apr 22 2007, 04:39 PM
Always make sure that you are wearing heavy clothes and a welding apron. Getting a welding burn on your private parts will definitely inhibit your sex life for a month or so.
And yes, this comes from real world experience.
It happened while welding in sway bar mounts on Betty's car (20 years ago....).
jonferns
Apr 22 2007, 06:14 PM
better yet...make sure your wearing clothes
Mueller
Apr 22 2007, 06:16 PM
wearing baggy sweatpants are a bad thing, even more so when using a wire wheel on a grinder
racunniff
Apr 22 2007, 07:33 PM
- Your knees are an insufficient clamp for a workpiece undergoing wire wheel TLC.
- Keep lots of adhesive bandages in the house
Yes, these items are related.
ws91420
Apr 22 2007, 07:51 PM
QUOTE(SirAndy @ Apr 22 2007, 04:31 PM)
Andy
Not to be confused with drinking and wenching
jd74914
Apr 22 2007, 08:18 PM
1) Never use a grinder without gloves and always wear safety glasses.
2) Always wear something inflammable when welding, catching your pants on fire hurts a lot.
Note to others: knotted wire wheels + contact with ungloved hands = lots of blood loss, removal of nail and entire finger tip, and last but not pretty much complete and total loss of feeling with fingers.
SGB
Apr 22 2007, 09:26 PM
Clay-
you stay away from those kinda "sway bars".
SGB
Apr 22 2007, 09:28 PM
Block a wheel before you jack up the car.
ConeDodger
Apr 22 2007, 09:36 PM
Don't under any circumstance help Gint with anything
UNDER the car...
GeorgeRud
Once the car is up on jackstands, give a medium-hard shake before you get nderneath it to be sure it's on there solidly. Also, if your jackstands use pins to set the height, be sure they're all the way through both sides of the jackstand before crawling underneath.
I'll also second that idea of keeping a jack or wood or blocks under some other part of the car as a last ditch safety item.
I've just started on my new project, which is the restoration/updating of a 1975 GMC motorhome. You have no idea of how big and heavy that sucker is compared to the 914! Besides jackstands, you use dimensional lumber (6x6s and such) to keep that thing in the air! Anyone have a lift that can handle a 12000 lb, 26 foot vehicle?
