QUOTE(Dave_Darling @ Apr 22 2007, 09:10 PM)
Those pictures illustrate the most typical problem: Tons of oil leaking. Could be even more, particularly going around corners and/or at high RPM, when the rocker box fills up.
Lower probability, higher consequence: Some crud falls in there, and travels down the pushrod tube to the oil sump, and then gets circulated around the engine's oil system. Perhaps something hard, like some metal bits. Or something that can plug an oil gallery. Either of those can be the cause of severe engine problems, after a little while...
depending on the engine rpm, they either blow out oil or suck in air (and other small items) ...
neither of which is desirable ...
Andy
