Well I finally get my exhaust leak all fixed and decide to take her out for a drive. I get about 5-6 miles out and then the problems start. First thing I notice is that when I come to a stop sign the car will not stay running. In fact if I put the clutch in while driving the car will stall. It starts right back up, but I have to keep the accelerator slightly pressed to keep it running. Not a huge deal, probably a little idle tweaking or the like.
The more disturbing problem happened on the way home. The car seemed to lose power...big time. And in addition to the lack of power it sputtery (is that a real word???) acceleration. This will be hard to explain so hopefully it makes sense. The car would just kind of dog along. No high engine revs or changes in engine sounds. The occasionally for a second or two the car would "hook up" and I would get the acceleration and pull I would expect from it.
I'm going to be replacing vacuum hoses which I am sure will help if not eliminate the first issue. But I'm stumped on the larger problem. Any thoughts guys and gals?
Thanks,
Troy
