Ok,
Can I do this, has it been done?
I need to weld up an oval hole in the passenger side suspension console, and I really dont want to drop the motor.
So, here is my thought.
Can I remove the wheel, remove the rear shock, remove the brake line, and ebrake...and whatever else is attached to the trailing arm.
Then slide a wrench up in to the inside bolt and somehow get it to magically come off without the need for an impact gun...
then take the three bolts off the outside, and drop the whole arm...leaving the axle attached...no need to move that...I dont think..
Then, after I cover everything with protective leather..weld the hole, ream it to the correct size, and re-assemble?
I know that taking the motor out is a 1-2 hour jobs, and not a really huge deal, but I figure I will need to remove all the stuff I mentioned anyways...so if I can save the motor removal piece...think its possible??
Rich
