Howard
Dec 3 2003, 10:59 PM
Is there any difference between an early (midship pump) and late (front pump) fuel tank?
skline
Dec 3 2003, 11:02 PM
I know the top fuel fill is different, the early having metal expansion tank as opposed to a plastic one on the late models.
Howard
Dec 3 2003, 11:28 PM
have a 73 with possible rust issues in tank. will later tank fit?
Joe Ricard
Dec 4 2003, 07:23 AM
Howard I just pulled out the tank on my 74. It looks really good no rust issues. Right now it is set up for carbs but the plug can easily be removed on the return line.
JFJ914
Dec 4 2003, 04:44 PM
The tanks have different P/N's but I think the only difference between them are the brackets for the vapor canister. Other than that they are interchangable after you change the outlet tube to suit your particular fuel pump setup.
Howard
Dec 4 2003, 05:29 PM
Thanks, John. Joe, I'm not sure it's bad, and think I have one locally. Will contact you if I need it.
Gint
Dec 4 2003, 06:23 PM
Yes. And you can easily use the tank filler top and also the expansion chamber (if the original car/tank had one) from the original tank if you prefer.
