QUOTE(Aaron Cox @ Apr 24 2007, 06:37 PM)
QUOTE(TROJANMAN @ Apr 24 2007, 02:18 PM)
you can remove the gear stack and check the sliders/teeth, but you do need to remove the tranny to do so.
It seems uncommon to lose just 4th gear.
Rule out all of the cheap/easy fixes first. did you check all of the linkage?
you can pull the gearstack out of the tranny without removing the trans. easy to do.
hmm... so it wont go into fourth AT the tranny either? so that rules out linkage....
defer to evil/thomas/redbeard for that one
Well to be perfectly honest, I did not remove the shifter linkage to do my test at the tranny, I just had him remove the rubber cover, and the boot at the firewall.
I checked the cone screws...and tried it by hand.
It could still be something in the shifter rod adjustment (he has been futzing with it)
So, by hand, I may have been hitting the stops in the shifter...
Its kinda tough to diagnose with a maximum of ten to fifteen minutes to look it over...
I am hoping the gang of 914 guys will smack him for taking such crappy care of the car, and guilt him into spending at least a few hours fixing all the little stuff.
Rich
