QUOTE(914nerd @ Apr 24 2007, 07:39 PM)
What would you recommend for a leaking master cylinder?
If rebuilding, where can you get the seal kits?
Otherwise, 17mm replacement? 19?
What is the cheapest place to get a new one fast?
Thanks again,
Charles
I realize you are in New Mexico and it is a little farther to the bumper of the car in front of you than here in California, but as others have said so eloquently "it's your brakes!"
Rebuilding is iffy, and it is a total pain to replace so why make a bet on rebuilding and have to do it twice?
While it would be nice to have a real choice to do the 17mm or the 19mm the fact is that the 19mm is much cheaper. Probably due to the fact that no one uses the 17mm?
I agree with GPR but you might check with Nate at 914Parts.com
Oh, by the way, if your master cylinder is leaking you might as well get yourself a pedal cluster rebuild bushing set as well. Brake fluid toasts your pedal cluster, especially if it has the original bushings.
