QUOTE(rhodyguy @ Apr 25 2007, 12:45 AM)
well...they sure look dif. are they used, reman, or what? if you wipe them down can you find any #s?
k
Axles were purchased used from 914-parts.com. I wiped the grease off 2 of them today and there were no #'s on them that I could find. I'll look closer after I clean them with solvent.
QUOTE(yarin @ Apr 25 2007, 09:23 AM)
Count the number of splines, make sure they are equal. For a -4 there should be 33 splines.
Yup, there are 33 splines
I would order new dowel pins from pelican.
That's what I'll do
PMB Performance sells an excellent kit for $59 each. I replaced all four. If I were you I would replace the weird ones.
I confess. I'm a collector (of all types of junk). I really did not need these used axles as I purchased a new axle with new CV joints on both ends ~25 years ago from Stoddards. The new CV's are sitting in may attic right now unused. The next time I'm up there I'll have to count the splines on them. I guess I bought the used CV's for something to do. After wiping the grease off 2 of the CV's and boots, I'll never buy used CV's for something to do again.
QUOTE(Eric_Shea @ Apr 25 2007, 11:04 AM)
The PO ground down the pins to fit in the VW bolt holes instead of doing it right by machining the bolt hole to fit the proper pin.
After punching out the roll pins I found that PO drilled out 2 of the holes so that the pins would fit. It looks like the holes were drilled with a hand drill and a dull bit. For whatever reason the PO ground only on the exposed part of the roll pin. See the attached picture below.
The metal boot will hang over the edge slightly because of this but, no worries.
I'm probably missing something but if the metal part of the boot hangs slightly over the edge of the machined step aren't the roll pins installed on the wrong side of the CV then?
