I built a nice solid 1911 motor with all new or rebuilt components, I fired it a couple of weeks ago, did the 20-25 min cam break-in and tuned in the carbs, I drove it around the block and decided to put newer carbs on it. The carbs went on this past Monday, I fired the motor and started to tune the carbs, the motor just stopped, I tried to start it and the starter just clunked, you could feel it through the entire car, I played with it and got the motor to start again it ran for 30 secs or so and then stopped same starter clunk, no movement. I pulled the starter and ran it on a bench, no problem, put in a differnt starter same thing clunk, the starters were getting really hot, put the car in 5th gear and tried to move it...no go...two of us tried no go, put one wheel up in the air and tried to turn the wheel nope!
I'm very frustrated, it seems to be siezed, not understanding why it ran for close to 45 mintues without a hitch, then no go. ANy suggestion of things to try before I pull the motor? I'll give anything a try!!
