FB914
Apr 26 2007, 04:18 PM
Before I drop $80 on a new switch I wanted to ask if there was anything other than a bad switch behind the brake pedal that would cause the brake lights to come on and stay on the entire time the car is running. Thanks Also, anyplace better than pelican to get the part - it's $80 there
SLITS
Apr 26 2007, 04:21 PM
If the disk that holds the switch arm is bent or if you installed a new MC and got the arm behind the disk so that the switch is always in the closed position, the lights will be on. You could also check into frayed/scraped wires.
Ask a couple of the parts whores if they have a used one (I don't).
FB914
Apr 26 2007, 06:59 PM
I had a shop put in a new MC - that must be the issue. thx
Dave_Darling
Apr 26 2007, 08:03 PM
The arm for the brake light switch is on the wrong side of the washer on the pushrod. BTDT!
--DD
Eric_Shea
Apr 26 2007, 10:13 PM
with her...
