i have a kit with all the replacement bulbs so i proceed to swap out bulbs. seems simple enough, but somethings goofy and one bulb works correctly in one spot and another doesn't, or i swap out new for old and it screws everything up, so it's nutty. that and my reverse lights don't work, so i test the contacts and there's something in the wiring that's wrong, because they won't come on that way.
ANYWAY, after a couple hours of screwing around i find the golden combo and everything works ('cept the reverse lights... but so what for now). the turn signals, running lights, brakes, e-lites, bingo!
i proceed to put the lenses back on and secure everything. i go to test it and now i only have running lights and e-flashers. that's not all... along with all the other things not working are these items:
- dashboard gen light
- dashboard e-brake light
- oil pressure light
- oil pressure
- turn signal indicator
- fuel level indicator
- high beam indicator
- gauge lights
- clock
- wipers
- headlights/high beams
any clues? i know there's a short somewhere, but why from just reinstalling the lenses???????
paul
edit: oh, and the e-brake indicator flashes with the e-lights when the brake is engaged...
