My custom 3 row double pass aluminum Fluidyne radiator started leaking like crazy for no apparent reason. I brought it to a local radiator shop and witnessed the pressure dunk test personally. It leaked profusely in about 15-20 areas on either side of the core where the tubes attach to the header of the core....on the upper half only. I'm told it's a total loss. I found a local shop that would recore it using a 2 row core...the 3 row core is extemely hard to abtain from what I've learned. The price for a 2 row recore is $680. I found a place in MI called Howe Racing and they said they'd build me a new copy of my radiator with two 1" rows double pass for $480. This is only a few bucks more than my Fluidyne from 5 years ago.
Question: Since I have a huge hole feeding air into my radiator (it is almost the size of the radiator itself.... 29.5" X 12"), do you agree that a 2 row design will probably do the job just fine? My original 3 row design kept my V-8 running below 180 degrees about 95% of the time and would only go up to 185-190 on those 100+ degree humid days. It also makes sense that airflow will be less restricted with a 2 row design over a 3 row design. I suppose I will find out exactly what the tradeoff will be shortly. I don't want to spend $1000+ on Renegade's radiator because of all the work that may be required to integrate it into my air tunnel design that flows through the hood. A close copy of what I had is my best bet....I believe. Anyone using the Rod Simpson 2 row double pass design? I'd be interested to hear how his design behaves?
Regards,
Bill
