So.... wake up this am, and run to costa mesa RD machine.
picked up my
-rebuilt heads-
-honed barrels-
-hastings rings-
craig downs came over, and we began some reassembly.. and parts cleaning.
i cc'd my heads and came up with just over 52cc which will make some great compression.
craig made a wicked filter console blockoff plate with an AN 10 fitting on the exit.
38mm oil pump installed, and -10 an lines for full flow built and installed
so with a 71 x 94 motor with 52cc heads, .030 deckheight will give me a CR of 9.3:1.
craig is the man. gapped rings, cleaned up mahle euro pistons, and brought over some loctite threas sealant for the galley plugs and the an fitting adapters.
so without shims i have .014 deckheight, which means i need some .016 shims to nail .030 deck.
need to get some base shims....
so then we went o'er to bill grimsteads casa. he wanted to verify timing and chase an exhaust leak, and possible carb dial in.
so craig chased the leak... to no avail yet.
made it run and verified/repainted timing mark.
so at 3200 rpm we dialed in 28 degreesa on his unilite, and checked it idle, and it was a few degrees before ZERO!
so his 'set up' dizzy escaped the setting up phase LOL. easy fix to set the inital advance to 12 and final to 28
so all in all... a productive day in corona.
carry on.
AA
