QUOTE(r_towle @ Apr 29 2007, 09:09 PM)
A Few musts from Andy's list above.
Adjustable Spring perches for the rear, or you cannot balance the car.
Adjustable struts for the front.
A good bearing solution, Either Elephant racing, or bearings, but something solid, not rubber.
I am not a big far of the stock torsion bar school...I have 23 mm torsion bars and 21mm sway bar...
Its certainly comes in two schools..one prefers stock torsion bars, because it allows faster turn in, and that is good in an autocross situation, but might make it settle to fast in a track situation on really fast decel into a corner.
The good quality adjustable koni's or fox shox will enable you to dial a certain amount of the nose dive out of the car, but the bilstiens do not adjust.
I have
23mm from t bars
180lb rear springs
21 mm fronts sway
srs roller bearings for all a-arms/trailing arms.
Determine what you will do, if track only, you will need stiffer suspension, and it will depend on which tracks you run also.
The adjustable perches allow you to run 2.5 inch diameter springs, and those are cheap enough to have several different sets to bring with you of different wieghts...
If the track is hilly, a stiff front end is key.
If its autocross, and supple front end is key, or you get to much push at slow speed turn in (again applicable to track, but it depends on the track)
Ask the racers in your area, on the tracks you are planning to run on, how they setup for each track, and be prepared to have several setups on hand for different tracks.
You can build up those parts over time.
Rich
It will be a dedicated race car... I have been all over the place with my ideas for this car but the roll cage really dictated everything... I am to old and to fat to play the contorsionist game getting over the side impact bars on any commuting basis.
I will drive it to the track for lack of a trailer at the moment.
The primary tracks I will be running it at are as follows:
Laguna seca
Sears Point
Thunderhill
On occasion I might make it out to Az. and run PIR
