QUOTE(Howard R @ Dec 5 2003, 01:28 AM)
Worn out is probably right. I had my stock 110 lb springs tested after the rear kept getting lower. They measured 68 lb. Now run 140 lb Eibach and Konis.
Actually the stock 914-4 springs were closer to the 68lb you had tested. The 914-6 had 100lb springs IIRC. At one time it was popular to upgrade the stock springs to the 914-6 units. Now most people prefer an even more aggressive setup, especially for dual use (street/autox).
You can increase the stiffness gradually by adding 140's and a big adjustable sway bar up front (on a soft setting). Then add stiffer rear springs and torsion bars in the future if you become a more frequent and competetive autocrosser.
Two theories on shocks: 1) Konis for adjustability - soft on the street and hard in competition. 2) Bilsteins for excellent grip in all conditions without adjusting, but the bilsteins add spring rate as well.
I have been using standard Bilsteins for street and track since '84. In fact the rears have been in continuous use since then and only now am I planning an upgrade as the damping rates aren't optimum for a car with 250# rear springs and slicks.
