My car just started acting funny recently but I think it might have something to do with spinning the engine backwards by accident.
The symptoms are:
1. When I start it up it emits black smoke for a little while then clears up.
2. From a stop when warm it blows smoke for a while if I take off hard and run it up to red line.
3. From a stop it sputters when accelerating normally but clears up if I go WOT.
4. It smells very rich when I'm at a stop light idling.
History:
It was having trouble idling at anything below 2K unless I let the clutch out a little and push it back in to drop the idle down. Most times it would drop to about 500 RPMs but sometimes it would go back to about 2K.
I accidentally spun the engine backwards by coasting down a driveway forward and letting the clutch out while in reverse. This blew the PCV valve out and scared the poop out of me. I put the valve back in and the idle problems went away.
It doesn't burn any oil.
Suggestions?
