QUOTE(Joe Owensby @ May 3 2007, 05:40 PM)
I bought a parts car that has the condensor located along the driver's side of the front trunk. Has holes behind the front bumper for air in, and holes on the inner wheel well for air exit. It has a squirrel cage fan to circulate the condensor air. I was thinking of mounting this on my car, but haven't made the final decision. It has the typical inside across the bottom of the dash evaporator unit. I bought a new Sanden compressor to use. If anyone has any comments on this type of condensor arrangement, I would appreciate knowing these. Hope this is not a hijack of your thrread. Below are some rough photos of the arrangement on the parts car. It was wrecked on the left front, so the air handling housing is broken open. One photo shows the inside of the trunk, and the other shows the exit holes. Seems to allow the spare tire to fit in OK.
How much of the front trunk room does the typical trunk floor AC condensor take up?
Joe
Joe thanks for the pics and you're not hijacking my thread, I hoped others like yourself would chime in. That setup is interesting but I'm not sure I want to cut entry/exit holes in the trunk sidewalls or behind the bumper. The Porsche 964/993's had a condensor similiar to what you have in the pic but they were mounted in the front fender,drivers side behind the headlight bucket. They have a fan that is as big as the condensor that moves a lot of air. The 911 evaporator is mounted in the smugglers box and I was thinking of making my own box so I could use a flat fan rather than a squirrel cage fan. If that would work I might be able to plumb the AC air thru the existing vents? Just thinking out loud here any suggestions are appreciated.
