QUOTE(Dan (Almaden Valley) @ May 4 2007, 08:13 AM)
QUOTE(Rotten Robby @ May 4 2007, 12:10 AM)
Dan,
Jake gets 170hp from this combo but I am not Jake. My suspension isn't as well developed as yours and I don't have anywhere near the 914 time you do either... In fact if we get to the same event I would appreciate some instruction if you can break free. This was fun but I have to tell you, a 2270 is not as easy a build as the stock motor. I was sure glad Mark was there peeking over my shoulder and in some instances actually doing the work. (Robby don't do no damn spirallocks)
Mark is the man if you have any doubt at all. He made all of the deck height measurement and CR setting as well as valve train geometry relatively easy.
You can feel the torque though... Mark uses that stand to test fire his 2056 motors and this one feels like it wants to jump right off the stand even at those low RPMs.
those spiral locks are a pain...at least until you do several. The last couple of pistons were much easier, once I got the hang of those spiral circlips.
Our cars should be an interesting comparison. I have a little more suspension and you have a bit more HP...I would be glad to give you some pointers at any time...we just need to get these cars back into running condition.
by the way, have you had any luck with the Submarine?
Dan,
My sway bars and torsion bars are stock. My bushings are stock. My springs are 140 Welts. My shocks and struts are Koni Yellow. The car is aligned and corner balanced. Pretty much street stuff...
I didn't want to go too far off the modification cliff until I had considerable seat time. The motor had to be done as I could not get the stock DJet to run correctly, even with considerable help from Martin Baker. I have been driving Datsun Z cars for 20+ years so I need to learn the car.
Mine should be back together pretty quickly. I have everything, the car is on the jackstands.
I have not really tried to sell the Submarine that aggressively. I have a guy interested right now but his concern is that it is more an autocross car and less a track car. I will have it out to our SVR event at Stockton next week.
