THIS IS NOT AN INTEREST TO BUY FEELER!! i just have a number of them on hand (not fs). any way i can do this without imposing on someone with a running fi car? oops, wrong forum. please move this if you find it appropriate in the garage.
k
ws91420
May 4 2007, 05:45 PM
QUOTE(rhodyguy @ May 4 2007, 12:10 PM)
k
You should be able put 12v to it and the pump should run but don't run it too long.
Gint
May 4 2007, 07:04 PM
I stick short hoses on all three and stick them in a drip pan of gasoline and power the pump.
Moving to the garage...
May 4 2007, 07:22 PM
QUOTE(Gint @ May 4 2007, 05:04 PM)
don't run it dry!
12V will do the trick ... Andy
rhodyguy
May 4 2007, 08:09 PM
thanks guys. i hate my car.
k
swl
May 4 2007, 08:14 PM
Just be conscious of electrical sparks around the gas pan!
On the 3 hose pumps you really need to do a wet test. The pop off valve can stick in bypass mode and just pump into the return line instead of delivery. When they do that you need new rubber to fix it and I haven't found a rebuild kit anywhere.
