thomasotten
Dec 5 2003, 01:54 PM
I am thinking of building a 2.0 engine to replace my existing 1.8. I know the long block is different, but what about the sheet metal, impeller, heat exchangers and all that? Also, will 2.0 liter heat exchangers work with a 1.8 engine?
-Thomas
Brad Roberts
Dec 5 2003, 01:57 PM
You almost answered yourself...
Tin is different (over the cylinders) intake runners/plenum are different/heat exchangers are different (however the 1.8 HE's have the same inside diameter as the 2.0
Everything else fits.
B
thomasotten
Dec 5 2003, 02:07 PM
so, then what you are saying is that I could mount a 2.0 heat exchanger/exhaust up to my 1.8 just fine?
Brad Roberts
Dec 5 2003, 02:13 PM
No problem.
Bolts right on. Its a BIG improvement on the 1.7 cars. Really wakes them up by installing 2.0 HE's.
Oh.. make sure you use the 2.0 muffler hanger also.
B
cork
Dec 5 2003, 02:48 PM
Thomas, are you going to use 2 liter heads,as brad said you will need the 2.0 sheet metal, or rework your 1.8 sheet metal, if just going to 2 liter p&c and 1.8 heads the sheet metal will work, and 2.0 heat exchanger are a up grade just about ever one uses, when staying with a stock set up.
Brad Roberts
Dec 5 2003, 02:53 PM
Buy 2.0 tin. Do not rework your 1.8 tin. It will look like hacked crap (and if it doesnt.. you spent too much time making it look nice..LOL)
B
seanery
Dec 5 2003, 03:39 PM
I got perfect 2.0 tin on ebay for $26. It was already sandblasted, too!
You can find it.
Mark Henry
Dec 5 2003, 08:24 PM
QUOTE(thomasotten @ Dec 5 2003, 11:54 AM)
Just the crank, rods, P&C's and heads are different, the rest is the same. You can use the 1.8 heads on a 2.0.
On my modified 1.8 heads I have 42X 38mm valves in them.
