QUOTE(BarberDave @ May 5 2007, 03:36 AM)
I would find a T-stat ,pulley.and wire to make the thing fuction properly. Porsche engineers disigned it that way for a reason. my 2 cents Dave
QUOTE(MecGen @ May 5 2007, 06:10 AM)
Hi
Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places.
The cooling system is very well thought of, but it needs to be working on a T4.
Later
QUOTE(URY914 @ May 5 2007, 07:23 AM)
QUOTE(MecGen @ May 5 2007, 05:10 AM)
Hi
Later
I agree 100%. Street cars need these pieces to work. Everything is there for a very good reason.
If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from
evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal.
