dflesburg
May 5 2007, 03:57 PM
1986 3.2 Carrera engine....
I have two bosch fuel pumps here, they look identical...
Bosch part #
0 580 464 021
or
0 580 463 010
they look the same other than the part number
John
May 5 2007, 05:41 PM
Why two pumps?
Do they both have check valves? Is there a Porsche number on them? Can you take a pic?
John
May 5 2007, 05:47 PM
I found this as a BOSCH reference:
0 580 464 021 (84-89 911 Carrera)
SLITS
May 6 2007, 01:21 AM
If this thread is still on page 1 by Monday ..... I can cross the Bosch numbers to Porsche for ya.
Eric_Shea
May 6 2007, 03:00 PM
What's the other one for...? I need one BAD.
dflesburg
May 6 2007, 08:30 PM
it must have come off my car when it was a four cylinder... they look almost identical except for the out end, the 911 one has more brass hardware... must be the check valve john talked about...
John
May 6 2007, 09:24 PM
The other pump BOSCH # 0 580 463 010
It cross references to 043 906 091
is a 914 pump (1975/1976) and has no check valve. I have one just like it on the shelf (if anyone wants one PM me)
Eric_Shea
May 6 2007, 10:06 PM
Need a -6 pump bad...
Assdragger pump took a crap (it waited until I filled the damn tank of course!)
jk76.914
May 7 2007, 07:26 PM
hmmm. My original '76 pump has a check valve. Pressure stays up for probly 15 minutes after the engine is shut off. Isn't that a checkvalve? Jim
John
May 7 2007, 11:48 PM
QUOTE(jk76.914 @ May 7 2007, 05:26 PM)
Have you a picture?
My late style pump has no check valve. It does maintain pressure until it bleeds back through the pump. (well it did until I put a 3.2 in there)
jk76.914
May 9 2007, 08:41 PM
QUOTE(John @ May 8 2007, 01:48 AM)
Have you a picture?
No. No picture. It looks like yours- one nipple at each end, no return nipple. It's original to the car.
Jim
