Sorry no pictures, so I will do my best to describe the problem.
I thought I installed the passenger and driver side windows in correctly, everything looks good but when I roll down the windows it drags the squeegee seal down into the channel It never did that before the seals are about a year old, I cleaned the windows so I don't understand what I might have done wrong. The actual trim that hold the seal in place was removed by the painter, and he bent it up a bit pulling it out. I did the best I could to straighten it, but since I didn't remove it he did, I'm not sure the correct way to mount it. There is a channel on one side, and I wonder if it is to slide under the edge of the door or not? It seems I might he the trim to close to the window so the pressure is against the seal and the glass causing it to be pulled down...
Can someone help me out? pictures would be great....
Thanks
