JBart
May 6 2007, 05:56 PM
I need some help here I took my fan off to replace the oil cooler seals and the bolts are different along with the looks of the fan itself . The first picture is the fan off of my 72'. The second fan is off ? it came with a box o parts. The part # of the second fan is 021 119 113 the fan off my car has no part #.
One of the 12pt. bolts on my car was stripped so I either need to find the same 12pt. bolts or can I switch the fan out so I can use regular hex head bolts either way is fine by me I just need to find the 12pt. bolts I didn't see any at PP
Thanks,
jbart
Also there is a picture of the bolt from my car.
RustyWa
May 6 2007, 06:04 PM
Looks like a fan that came on a car with a smog pump. The pully extension would bolt up to that location.
Joe Owensby
May 6 2007, 06:12 PM
The second fan, on the right, looks exactly like the one on my 71 1.7. Joe O
QUOTE(JBart @ May 6 2007, 03:56 PM)
Thanks,
jbart
Aaron Cox
May 6 2007, 06:21 PM
i have used both on mine.
i believe i read something on STF about the left one being slightly more efficient?
TheCabinetmaker
May 6 2007, 06:32 PM
How do you work on a 914 and keep a fingernail that long and clean?
JBart
SO if I use the flat fan instead of the coned fan what kind of bolt should I use just a regular 8mm bolt or is there a special type of bolt?
Thanks,
jbart
TheCabinetmaker
May 6 2007, 06:34 PM
regular bolt. Correct length is important. not sure about hardness of bolt.
Dave_Darling
May 6 2007, 07:56 PM
My car has the second type of fan, but also uses CV joint bolts like the first type does. The Kap'n has said not to switch around types of bolts, but I'm not sure why.
--DD
JBart
May 6 2007, 11:06 PM
Thanks guys,
I went to the local VW shop and she had some CV bolts so hopefully mon. after work I can play with it and see if they are going to work they are a lil' longer so I might need to cut them down a little to make them work.
As far as the pretty nails you should see my DRESS!!!!!
Really thats where the wife comes in real handy "taking pictures" I point she shoots.
SLITS
May 7 2007, 12:00 AM
I was told one was early and one was on later cars. The one with the rubber boobie and slope to the fan blades should be the more efficient one.
McMark
May 7 2007, 10:28 AM
The 'cone' fan came on early 1.7 motors. It uses shorter bolts that will not work with the late style fan. And conversely, the late style bolts are too long for an early fan. That being said, the only two factors you need worry about for bolts is thread engagement (not too short) and protrusion into the front main seal (not too long). Other than that it's a plain ol' 8 x 1.25 bolt.
