one of these two lines is leaking bad. thought it was the oil psi hose on top but i fixed that leak so i know it is coming from the pump outlet or the return fitting.
the blower housing has to be split and removed to get to these and then it will be not alot of fun removing and reinstalling these lines on my back under the car.
have to pull the blower housing because the cooling flap above the oil cooler is screwed down and i need to release it before i can get to the oil fittings.
also, i have an exhaust leak at one stub pipe flange that i can't fix. the flanges are out of alignment and will not seal. unfortuately the primary pipes are fused to the collector so i can't adjust that way. Tried with a torch and pb blaster this weekend.
this is getting to be not so fun.
