QUOTE(wbergtho @ May 9 2007, 10:48 PM)
I know a guy in Upland, CA that can convert your rear trailing arms to 911 rotors & calipers. All you have to do after that is get a pair of custom emergency brake cables made up from Terrycable in Hesparia, CA. Done! Let me know if you want his number? His name is Randy Beck and he owns a shop named RPM (actually in Rancho Cucamonga, CA).
There's nothing on a 911 caliper to attach the E brake cable to. 911's use small drum brakes inside of the rear rotor.
Does Randy convert the rear trailing arms so that you can attach the drum brakes?
I'm sorry if I sound like a dick, I'm tired and I should be in bed.
