QUOTE(Eric_Shea @ May 10 2007, 11:14 AM)
Sail vinyl kits are cheap. The only way to do this "right" is to simply get a new kit. (under $40 clams right?)
I used "Goof-Off" to get the adhesive off my car.
John's right... I'm not sure the adhesive would work on the vinyl. Vinyl is a gauze base which is adhered (sic) to the vinyl. The remover would probably damamge it.
Just buy new...
I have no problem with buying a new kit...I want to just replace the one side...the other two are perfect. Unless I order from the same supplier (which I have no idea who I bought it from)...it won't match.QUOTE(Grelber @ May 10 2007, 11:21 AM)
Before you do that, try an old wallpaper trick. Put a SMALL hole in the middle of the bubble with a straight pin. Then, put a towel over the bubble and press for a couple of seconds with a hot iron. The iron heats up the glue, and usually reseals the bubble (and the hole).
Worth a try
If it doesn't work, you needed a new one anyway.
QUOTE(tracks914 @ May 10 2007, 03:56 PM)
QUOTE(Grelber @ May 10 2007, 10:21 AM)
Or better yet, get a large hypodermic needle. Inject a small amount of adhesive remover into the bubble. Just enough to soften the glue. Work it around the bubble then squeeze as much of it out the hole as you can. As the adhesive evaporates the glue will reset.
If that doesn't work, buy a new piece and do it right.
Another great idea
